Introduction
Tools
No tools specified.
Remove all the components from the static end of the high-pressure cylinder with the proper tools.
Clean all Blue Goop off the high-pressure cylinder with isopropyl alcohol or a similar cleaning agent.
Apply high vacuum grease to the O-ring.
Slide the O-ring onto the groove of the high-pressure seal.
Insert the high-pressure seal into the end of the high-pressure cylinder.
Insert the static back-up behind the high-pressure seal.
Apply blue goop to both ends of HP cylinder threads
Reassemble HP cylinder into intensifier assembly
