Skip to main content
Older Newer
  2. Unthread hose from hydraulic fitting Loosen 1/4" gland nut from side inlet of valve body Unthread 1/4" gland nut from side inlet of valve body
    • Loosen 1/4" gland nut from side inlet of valve body
    • Unthread 1/4" gland nut from side inlet of valve body
  3. Clean 1/4" gland nut of all blue goop with isopropyl alcohol Loosen 3/8" HP gland from outlet adapter using 13/16" and 1" wrench Unthread 3/8: HP gland from outlet adapter
    • Clean 1/4" gland nut of all blue goop with isopropyl alcohol
    • Loosen 3/8" HP gland from outlet adapter using 13/16" and 1" wrench
    • Unthread 3/8: HP gland from outlet adapter
  5. Apply o-ring lubricant to o-ring from kit for hydraulic fitting Replace o-ring on hydraulic fitting with o-ring in kit (smallest o-ring in kit) Loosen adapter fitting from Actuator Housing using 1-1/4" and 1-1/16" wrench
    • Replace o-ring on hydraulic fitting with o-ring in kit (smallest o-ring in kit)
  6. Unthread adapter fitting from actuator housing Apply o-ring lubricant to largest o-ring in kit Replace o-ring on adapter fitting with largest o-ring in kit
  7. Loosen actuator housing from Valve Body using 1-1/16" and 7/8" wrench Unthread actuator housing from valve body Push Piston out of actuator housing through oil port using included dowel
  8. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to o-ring and back-up ring
    • Apply o-ring lubricant to o-ring and back-up ring
  9. Slide new back-up ring (flat) into groove of piston. Make sure concave of back-up ring side is towards o-ring Slide new o-ring (rounded) into groove of piston
    • Slide new back-up ring (flat) into groove of piston.
    • Make sure concave of back-up ring side is towards o-ring
    • Slide new o-ring (rounded) into groove of piston
  10. Loosen outlet fitting from bleed down valve body using 7/8" and 13/16" wrench Unthread outlet fitting from bleed down valve body Remove HP Seat from bleed down valve body and discard
    • Remove HP Seat from bleed down valve body and discard
  11. Remove Flow Reducer from outlet adapter Clean outlet adapter of all blue goop with isopropyl alcohol Loosen back-up screw from top of bleed down valve body using  5/16" socket wrench
    • Clean outlet adapter of all blue goop with isopropyl alcohol
    • Loosen back-up screw from top of bleed down valve body using 5/16" socket wrench
  12. Unthread seal back-up screw from top of bleed down valve body Clean seal back-up screw with isopropyl alcohol Push components through bleed down valve body with included dowel
    • Clean seal back-up screw with isopropyl alcohol
  13. Clean bleed down valve body with isopropyl alcohol or similar Apply high vacuum grease to Needle Slide back-up screw on to needle so flat end of needle is flush with non threaded part of back-up screw
    • Clean bleed down valve body with isopropyl alcohol or similar
    • Slide back-up screw on to needle so flat end of needle is flush with non threaded part of back-up screw
  14. Slide bushing onto point of needle with chamfered end towards back-up screw Place hoop onto HP Seal with tapered end towards seal and opposite from o-ring Place HP seal assembly onto point of needle with hoop first
    • Place hoop onto HP Seal with tapered end towards seal and opposite from o-ring
  15. Apply high vacuum grease to exterior of HP seal, hoop, and bushing Apply high vacuum grease to internal threads of bleed down valve body Insert high pressure needle assembly into top of bleed down valve body with point first
  16. Push seal backup screw inside of valve body until it bottoms out Take seal backup screw out of body and apply a layer of blue goop to threads Thread in back-up screw into top of bleed down valve body
  17. Tighten back-up screw to top of bleed down valve body using a 5/16" socket wrench Place flow reducer into hole beneath seat cavity in outlet adapter Apply a layer of blue goop to external threads and seat cavity of outlet adapter
    • Tighten back-up screw to top of bleed down valve body using a 5/16" socket wrench
    • Place flow reducer into hole beneath seat cavity in outlet adapter
  18. Place poppet seat into seat cavity of outlet adapter Apply a layer of blue goop to top of poppet seat sitting in outlet adapter Thread outlet adapter into valve body
  19. Using a 1" wrench on outlet adapter and a 7/8" wrench on the valve body, tighten securely Apply a layer of blue goop to external threads of valve body Thread actuator housing onto valve body
    • Thread actuator housing onto valve body
  20. Tighten using a 1-1/16" wrench on actuator housing and a 7/8" wrench on valve body Apply blue goop to 3/8" gland nut threads Thread 3/8" gland nut with HP tubing into bleed down valve adapter
    • Tighten using a 1-1/16" wrench on actuator housing and a 7/8" wrench on valve body
    • Apply blue goop to 3/8" gland nut threads
    • Thread 3/8" gland nut with HP tubing into bleed down valve adapter
  21. Tighten gland nut into bleed down valve adapter using 13/16" and 5/8" wrench Apply blue goop to 1/4" gland nut threads Thread 1/4" gland nut into side of bleed down valve body
    • Tighten gland nut into bleed down valve adapter using 13/16" and 5/8" wrench
    • Apply blue goop to 1/4" gland nut threads
    • Thread 1/4" gland nut into side of bleed down valve body
  22. Tighten gland nut to side of bleed down valve body with using 3/4" and 5/8" wrench Thread adapter fitting into actuator housing Tighten adapter fitting into actuator housing
    • Tighten gland nut to side of bleed down valve body with using 3/4" and 5/8" wrench
    • Thread adapter fitting into actuator housing
    • Tighten adapter fitting into actuator housing
  23. Thread hydraulic fitting into hydraulic adapter Tighten hydraulic fitting into hydraulic adapter Thread hydraulic hose onto hydraulic fitting
    • Thread hydraulic fitting into hydraulic adapter
    • Tighten hydraulic fitting into hydraulic adapter
    • Thread hydraulic hose onto hydraulic fitting
  24. Tighten hydraulic hose to hydraulic fitting using 7/8" and 3/4" wrench Turn pump ON and continue cutting process
Adam Dumas
36 Guides authored
Xnet access
Connect with us
