Skip to main content
Older Newer
  3. Clean gland nut of all blue goop with isopropyl alcohol Loosen hydraulic fitting from adapter fitting using 1-1/4" and 7/8" wrench Unthread hydraulic fitting from adapter fitting
  4. Apply o-ring lubricant to o-ring from kit for hydraulic fitting Replace o-ring around hydraulic fitting with o-ring in kit (smallest o-ring in kit) Loosen adapter fitting from Actuator Housing using 1-1/4" and 1-1/16" wrench
  5. Unthread adapter fitting from actuator housing Apply o-ring lubricant to largest o-ring in kit Replace o-ring on adapter fitting with largest o-ring in kit
  6. Loosen actuator housing from Valve Body using 1-1/16" and 7/8" wrench Unthread actuator housing from valve body Push the Piston out of actuator housing through oil port using included dowel
    • Push the Piston out of actuator housing through oil port using included dowel
  7. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to o-ring and back-up ring
    • Apply o-ring lubricant to o-ring and back-up ring
  8. Slide new back-up o-ring (flat) to groove of piston            Make sure concave of back-up ring side is towards o-ring Slide new o-ring (rounded) to groove of piston Insert piston assembly into actuator housing and push with included dowel
  9. Loosen outlet fitting from bleed down valve body using 7/8" and 13/16" wrench Unthread outlet fitting from bleed down valve body
  10. Remove HP Seat from bleed down valve body Remove Flow Reducer from outlet adapter
    • Remove HP Seat from bleed down valve body
  11. Clean outlet adapter of all blue goop with isopropyl alcohol Discard seat Loosen back-up screw from top of bleed down valve body using a 5/16" ratchet
    • Clean outlet adapter of all blue goop with isopropyl alcohol
    • Discard seat
    • Loosen back-up screw from top of bleed down valve body using a 5/16" ratchet
  12. Unthread seal back-up screw from top of bleed down valve body Clean seal back-up screw with isopropyl alcohol Push components through bleed down valve body with included dowel
    • Clean seal back-up screw with isopropyl alcohol
  13. Clean bleed down valve body with isopropyl alcohol Apply high vacuum grease to Needle Slide back-up screw on to needle to flat end of needle is flush with non threaded part of back-up screw
  14. Slide bushing onto point of needle with chamfered end towards back-up screw Place hoop with tapered end onto onto HP Seal opposite from o-ring Place HP seal assembly onto point of needle with hoop first
    • Place hoop with tapered end onto onto HP Seal opposite from o-ring
  15. Apply high vacuum grease to exterior of HP seal, hoop, and bushing Apply high vacuum grease to internal threads of bleed down valve body Insert high pressure needle assembly into top of bleed down valve body with point first
  16. Push seal backup screw inside of valve body until it bottoms out Take seal backup screw out of body and apply a layer of blue goop to threads Thread in back-up screw into top of bleed down valve body
  17. Tighten back-up screw to top of bleed down valve body using a 5/16" ratchet Place flow reducer into hole beneath seat cavity in outlet adapter Apply a layer of blue goop to external threads and seat cavity of outlet adapter
    • Place flow reducer into hole beneath seat cavity in outlet adapter
  18. Place poppet seat into seat cavity of outlet adapter Apply a layer of blue goop to top of poppet seat sitting in outlet adapter Thread outlet adapter into valve body
  19. Using a 1" wrench on outlet adapter and a 7/8" wrench on the valve body, tighten securely Apply a layer of blue goop to external threads of valve body Thread actuator housing onto valve body
    • Thread actuator housing onto valve body
  20. Tighten using a 1-1/16" wrench on actuator housing and a 7/8" wrench on valve body
    • Tighten using a 1-1/16" wrench on actuator housing and a 7/8" wrench on valve body
  21. Apply blue goop to gland nut threads
    • Apply blue goop to gland nut threads
    • Tighten gland nut into bleed down valve adapter using 13/16" and 5/8" wrench
  22. Apply blue goop to gland nut threads Thread in gland nut to side of bleed down valve body Tighten gland nut to side of bleed down valve body with using 3/4" and 5/8" wrench
    • Tighten gland nut to side of bleed down valve body with using 3/4" and 5/8" wrench
  23. Thread in adapter fitting into actuator housing Tighten adapter fitting into actuator housing Thread in hydraulic adapter into adapter fitting
    • Thread in adapter fitting into actuator housing
    • Tighten adapter fitting into actuator housing
    • Thread in hydraulic adapter into adapter fitting
  24. Tighten hydraulic fitting into adapter fitting Thread hydraulic hose to hydraulic fitting Tighten hydraulic hose to hydraulic fitting using 7/8" and 3/4" wrench
    • Tighten hydraulic fitting into adapter fitting
  25. Turn pump ON and continue cutting process
Adam Dumas
36 Guides authored
Xnet access
Connect with us
