Skip to main content
Older Newer
  3. Clean gland nut of all blue goop with isopropyl alcohol loosen gland nut from outlet fitting (connected to valve body) using 13/16" and 5/8" wrench Unthread gland nut from outlet fitting (connected to valve body)
    • loosen gland nut from outlet fitting (connected to valve body) using 13/16" and 5/8" wrench
    • Unthread gland nut from outlet fitting (connected to valve body)
  5. Apply o-ring lubricant to o-ring from kit for hydraulic fitting Replace o-ring around hydraulic fitting with o-ring in kit (smallest o-ring in kit) Loosen adapter fitting from Actuator Housing using 1-1/4" and 1-1/16" wrench
  6. Unthread adapter fitting from actuator housing Apply o-ring lubricant to largest o-ring in kit Replace o-ring on adapter fitting with largest o-ring in kit
  7. Loosen actuator housing from Valve Body using 1-1/16" and 7/8" wrench Unthread actuator housing from valve body Push the Piston out of actuator housing through oil port using included dowel
    • Push the Piston out of actuator housing through oil port using included dowel
  8. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to cover all of o-ring and back-up ring
    • Loosen 3/8" to 1/4" adapter from outlet fitting with 7/8" and 13/16" wrench
    • Unthread 3/8" to 1/4" adapter from outlet fitting
    • Remove HP Seat from bleed down valve body
    • Clean outlet adapter of all blue goop with isopropyl alcohol
    • Discard seat
    • Loosen back-up screw from top of bleed down valve body using a 5/16" ratchet
    • Clean seal back-up screw with isopropyl alcohol
  10. Clean bleed down valve body with isopropyl alcohol Apply high vacuum grease to Needle
  11. Slide bushing onto point of needle with chamfered end towards back-up screw Place hoop with tapered end onto non o-ring side of HP Seal Place HP seal assembly onto point of needle with hoop first
  12. Apply high vacuum grease to exterior of HP seal, hoop, and bushing Apply high vacuum grease to internal threads of bleed down valve body
  13. Push seal backup screw inside of valve body until it bottoms out Take seal backup screw out of body and apply a layer of blue goop to threads
  14. Tighten back-up screw to top of bleed down valve body using a 5/16" ratchet Place flow reducer into hole beneath seat cavity in the outlet adapter
  15. Place poppet seat into seat cavity of outlet adapter Apply a layer of blue goop to top of poppet seat sitting in outlet adapter
  16. Using a 1" wrench on outlet adapter and a 7/8" wrench on the valve body, tighten securely
  17. Tighten using a 1-1/16" wrench on housing body and a 7/8" wrench on valve body Thread in bleed down valve adapter to bleed down valve outlet
    • Tighten using a 1-1/16" wrench on housing body and a 7/8" wrench on valve body
    • Thread in bleed down valve adapter to bleed down valve outlet
    • Tighten bleed down valve adapter to bleed down valve outlet
  18. Apply blue goop to gland nut Thread in gland nut with HP tubing into bleed down valve adapter
    • Apply blue goop to gland nut
  19. Thread in gland nut to side of bleed down valve body Tighten gland nut to side of bleed down valve body with....
    • Tighten gland nut to side of bleed down valve body with....
    • Thread in adapter fitting into actuator housing
  20. Tighten adapter fitting into actuator housing Thread in hydraulic adapter into adapter fitting
    • Tighten adapter fitting into actuator housing
    • Thread in hydraulic adapter into adapter fitting
    • Tighten hydraulic fitting into adapter fitting
  21. Thread hydraulic hose to hydraulic fitting
Adam Dumas
36 Guides authored
Xnet access
Connect with us
