Skip to main content
Older Newer
  2. Unthread hose from hydraulic fitting Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench Unthread hydraulic fitting from adapter fitting
    • Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench
  3. Apply o-ring lubricant to o-ring from kit for hydraulic fitting Replace o-ring around hydraulic fitting with o-ring in kit (smallest o-ring in kit)
    • Loosen adapter fitting from Actuator Housing with1-1/4" and 1-1/16" wrench
  4. Unthread adapter fitting from actuator housing Apply o-ring lubricant to largest o-ring in kit
    • Loosen HP tubing from Bleed Down Valve inlet
  5. Unthread gland nut from outlet adapter Clean gland nut of all blue goop with isopropyl alcohol
  6. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to cover all of o-ring and back-up ring
  7. Slide new back-up o-ring (flat) to groove of piston            Make sure concave of back-up ring side is towards o-ring Slide new o-ring (rounded) to groove of piston Insert piston assembly into actuator housing and push with included dowel
  8. Thread adapter fitting to actuator housing Tighten adapter fitting to actuator housing using 1-1/4" and 1-1/16" wrench
    • Loosen 3/8" to 1/4" adapter from bleed down valve outlet adapter using......
    • Loosen bleed down valve adapter from bleed down valve using.....
  9. Apply high vacuum grease to Needle Slide back-up screw on to needle to flat end of needle is flush with non threaded part of back-up screw Slide bushing onto point of needle with chamfered end towards back-up screw
  10. Place hoop with tapered end onto non o-ring side of HP Seal Place HP seal assembly onto point of needle with hoop first Apply high vacuum grease to exterior of HP seal, hoop, and bushing
  11. Apply high vacuum grease to internal threads of bleed down valve body Insert high pressure needle assembly into top of bleed down valve body with point first Push seal backup screw inside of valve body until it bottoms out
  12. Take seal backup screw out of body and apply a layer of blue goop to threads Thread in back-up screw into top of bleed down valve body
  13. Place flow reducer into hole beneath seat cavity in the outlet adapter Apply a layer of blue goop to external threads and seat cavity of outlet adapter Place poppet seat into seat cavity of outlet adapter
  14. Apply a layer of blue goop to top of poppet seat sitting in outlet adapter Thread outlet adapter into valve body Using a 1" wrench on outlet adapter and a 7/8" wrench on the valve body, tighten securely
  15. Apply a layer of blue goop to external threads of valve body Thread valve body into housing Using a 1 1/16" wrench on housing body and a 7/8" wrench on valve body, tighten wrench tight
    • Using a 1 1/16" wrench on housing body and a 7/8" wrench on valve body, tighten wrench tight
Adam Dumas
36 Guides authored
Xnet access
Connect with us
