Skip to main content
Older Newer
  2. Unthread hose from hydraulic fitting Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench Unthread hydraulic fitting from adapter fitting
    • Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench
    • Loosen adapter fitting from Actuator Housing with1-1/4" and 1-1/16" wrench
    • Loosen HP tubing from Bleed Down Valve inlet
  3. Unthread gland nut from outlet adapter Clean gland nut of all blue goop with isopropyl alcohol
  4. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to cover all of o-ring and back-up ring
  5. Slide new back-up o-ring (flat) to groove of piston            Make sure concave of back-up ring side is towards o-ring Slide new o-ring (rounded) to groove of piston Insert piston assembly into actuator housing and push with included dowel
  6. Thread adapter fitting to actuator housing Tighten adapter fitting to actuator housing using 1-1/4" and 1-1/16" wrench
    • Loosen 3/8" to 1/4" adapter from bleed down valve outlet adapter using......
    • Loosen bleed down valve adapter from bleed down valve using.....
  7. Apply high vacuum grease to Needle Slide back-up screw on to needle to flat end of needle is flush with non threaded part of back-up screw Slide bushing onto point of needle with chamfered end towards back-up screw
  8. Place hoop with tapered end onto non o-ring side of HP Seal Place HP seal assembly onto point of needle with hoop first Apply high vacuum grease to exterior of HP seal, hoop, and bushing
  9. Apply high vacuum grease to internal threads of bleed down valve body Insert high pressure needle assembly into top of bleed down valve body with point first Push seal backup screw inside of valve body until it bottoms out
  10. Take seal backup screw out of body and apply a layer of blue goop to threads
Adam Dumas
36 Guides authored
Xnet access
Connect with us
