Skip to main content
Older Newer
  2. Unthread hose from hydraulic fitting Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench Unthread hydraulic fitting from adapter fitting
    • Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench
    • Loosen adapter fitting from Actuator Housing with1-1/4" and 1-1/16" wrench
    • Loosen HP tubing from Bleed Down Valve inlet
  3. Unthread gland nut from outlet adapter Clean gland nut of all blue goop with isopropyl alcohol
  4. Discard o-ring and backup ring from piston Inspect piston, if damage is visible, replace Apply o-ring lubricant to cover all of o-ring and back-up ring
    • Loosen 3/8" to 1/4" adapter from bleed down valve outlet adapter using......
    • Loosen bleed down valve adapter from bleed down valve using.....
Adam Dumas
36 Guides authored
Xnet access
Connect with us
