Parts
- Bleed Down Valve Body II #12943
- Bleed Down Valve Needle II #12942
- Bleed Down Valve High-Pressure Seal #11321
- Bleed Down Valve Seal Hoop #11323
- Bleed Down Valve Stem Bushing #11324
- Poppet Seat #11141
- Seal Back-up Screw #12945
- Outlet Adapter #12944
- Flow Reducer #11743
- Bleed Down Valve Housing Body #11779
- Bleed Down Valve Hydraulic Piston #11778
- Back-up O-Ring #11680-114
- Male to Female Hydraulic Adapter #11796
- O-ring SAE #12880-912
- O-ring Lube #13969
- High Vacuum Grease #11447
- Blue Goop #11111
Always make sure all high-pressure water has been removed from valve by following machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
Turn OFF all hydraulic and water pressure to bleed-down valve
Loosen hydraulic hose from hydraulic fitting using 7/8" and 3/4" wrench
Unthread hose from hydraulic fitting
Loosen hydraulic fitting from Adapter Fitting 1-1/4" and 7/8" wrench
Unthread hydraulic fitting from adapter fitting
Apply o-ring lubricant to o-ring from kit for hydraulic fitting
Replace o-ring around hydraulic fitting with o-ring in kit (smallest o-ring in kit)
Loosen adapter fitting from Actuator Housing with1-1/4" and 1-1/16" wrench
Unthread adapter fitting from actuator housing
Apply o-ring lubricant to largest o-ring in kit
Replace o-ring on adapter fitting with largest o-ring in kit
Loosen actuator housing from Valve Body using 1-1/16" and 7/8" wrench
Unthread actuator housing from valve body
Loosen HP tubing from Bleed Down Valve inlet
Unthread gland nut with HP tubing from bleed down valve inlet
Clean gland nut of all Blue Goop with isopropyl alcohol
Loosen gland nut from outlet fitting using 13/16" and 5/8" wrench
Unthread gland nut from outlet adapter
Clean gland nut of all blue goop with isopropyl alcohol
Push Piston out of actuator housing through oil port using included dowel
Discard o-ring and backup ring from piston
Inspect piston, if damage is visible, replace
Apply o-ring lubricant to cover all of o-ring and back-up ring
Slide new back-up o-ring (flat) to groove of piston Make sure concave of back-up ring side is towards o-ring
Slide new o-ring (rounded) to groove of piston
Insert piston assembly into actuator housing and push with included dowel
Thread adapter fitting to actuator housing
Tighten adapter fitting to actuator housing using 1-1/4" and 1-1/16" wrench
Loosen 3/8" to 1/4" adapter from bleed down valve outlet adapter using......
Unthread 3/8" to 1/4" adapter from bleed down valve adapter
Loosen bleed down valve adapter from bleed down valve using.....
Unthread bleed down valve adapter from bleed down valve
Remove Seat from bleed down valve body
Remove Flow Reducer from bleed down valve adapter
Clean outlet adapter of all blue goop
Unthread seal back-up screw from top of bleed down valve body
Push components through bleed down valve body with included dowel
Clean bleed down valve body with isopropyl alcohol
Apply high vacuum grease to Needle
Slide back-up screw on to needle to flat end of needle is flush with non threaded part of back-up screw
Slide bushing onto point of needle with chamfered end towards back-up screw
Place hoop with tapered end onto non o-ring side of HP Seal
Place HP seal assembly onto point of needle with hoop first
