Always make sure all high-pressure water has been removed from the valve by following the machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
Turn OFF all hydraulic and water pressure to the bleed-down valve.
Loosen the hydraulic hose from the hydraulic fitting using 7/8" and 3/4" wrench.
Unthread the hydraulic hose from the hydraulic fitting.
Loosen the 1/4" gland nut from the side inlet of the valve body.
Unthread the 1/4" gland nut from the side inlet of the valve body.
Clean 3/8" gland nut of all blue goop with isopropyl alcohol
Loosen 3/8" HP gland from outlet adapter using 13/16" and 1" wrench
Unthread 3/8" HP gland from outlet adapter
Loosen hydraulic fitting from adapter fitting using 1-1/4" and 7/8" wrench
Unthread hydraulic fitting from adapter fitting
Apply o-ring lubricant to o-ring from kit for hydraulic fitting
Replace o-ring on hydraulic fitting with o-ring in kit (smallest o-ring in kit)
Loosen adapter fitting from Actuator Housing using 1-1/4" and 1-1/16" wrench
Unthread adapter fitting from actuator housing
Apply o-ring lubricant to largest o-ring in kit
Replace o-ring on adapter fitting with largest o-ring in kit
Loosen actuator housing from Valve Body using 1-1/16" and 7/8" wrench
Unthread actuator housing from valve body
Push Piston out of actuator housing through oil port using included dowel
Discard o-ring and back-up ring from piston
Inspect piston, if damage is visible, replace
Apply o-ring lubricant to o-ring and back-up ring
Slide new back-up ring (flat) into groove of piston.
Make sure concave of back-up ring side is towards o-ring
Slide new o-ring (rounded) into groove of piston
Insert piston assembly into actuator housing and push with included dowel
Loosen outlet fitting from bleed down valve body using 7/8" and 13/16" wrench
Unthread outlet fitting from bleed down valve body
Remove HP Seat from bleed down valve body and discard
Remove Flow Reducer from outlet adapter
Clean outlet adapter and flow reducer of all blue goop with isopropyl alcohol
Loosen back-up screw from top of bleed down valve body using 5/16" socket wrench
Unthread Seal Back-up Screw from top of bleed down valve body
Clean seal back-up screw with isopropyl alcohol
Push components through bleed down valve body with included dowel
Clean bleed down valve body with isopropyl alcohol or similar
Apply High Vacuum Grease to Needle
Slide back-up screw on to needle so flat end of needle is flush with non threaded part of back-up screw
Slide bushing onto point of needle with chamfered end towards back-up screw
Place hoop onto HP Seal with tapered end towards seal and opposite from o-ring
Place HP seal assembly onto point of needle with hoop first
Apply high vacuum grease to exterior of HP seal, hoop, and bushing
Apply high vacuum grease to internal threads of bleed down valve body
Insert high pressure needle assembly into top of bleed down valve body with point first
Push seal back-up screw inside of valve body until it bottoms out
Take seal back-up screw out of body and apply a layer of blue goop to threads
Thread in back-up screw into top of bleed down valve body
Tighten back-up screw to top of bleed down valve body using a 5/16" socket wrench
Place flow reducer into hole beneath seat cavity in outlet adapter
Apply a layer of blue goop to external threads and seat cavity of outlet adapter
Place poppet seat into seat cavity of outlet adapter
Apply a layer of blue goop to top of poppet seat sitting in outlet adapter
Thread outlet adapter into valve body
Using a 1" wrench on outlet adapter and a 7/8" wrench on the valve body, tighten securely
Apply a layer of blue goop to external threads of valve body
Thread actuator housing onto valve body
Tighten using a 1-1/16" wrench on actuator housing and a 7/8" wrench on valve body
Apply blue goop to 3/8" gland nut threads
Thread 3/8" gland nut with HP tubing into bleed down valve adapter
Tighten gland nut into bleed down valve adapter using 13/16" and 5/8" wrench
Apply blue goop to 1/4" gland nut threads
Thread 1/4" gland nut into side of bleed down valve body
Tighten gland nut to side of bleed down valve body with using 3/4" and 5/8" wrench
Thread adapter fitting into actuator housing
Tighten adapter fitting into actuator housing using 1-1/4" and 1-1/16" wrench
Thread hydraulic fitting into hydraulic adapter
Tighten hydraulic fitting into hydraulic adapter
Thread hydraulic hose onto hydraulic fitting
Tighten hydraulic hose to hydraulic fitting using 7/8" and 3/4" wrench
Turn pump ON and continue cutting process
You're viewing a previously published revision of this guide. View latest revision
Older
Newer
Jan 08, 2014 - 12:01:30
Jan 16, 2014 - 02:01:30
Jan 16, 2014 - 02:01:17
Jan 16, 2014 - 02:01:08
Jan 16, 2014 - 02:01:52
Jan 16, 2014 - 02:01:41
Jan 16, 2014 - 02:01:31
Jan 16, 2014 - 02:01:06
Jan 13, 2014 - 08:01:45
Jan 08, 2014 - 12:01:54
Jan 08, 2014 - 12:01:53
Jan 08, 2014 - 12:01:38
Jan 08, 2014 - 12:01:06
Jan 08, 2014 - 12:01:04
Jan 08, 2014 - 12:01:22
Jan 08, 2014 - 12:01:21
Jan 08, 2014 - 12:01:40
Jan 08, 2014 - 12:01:39
Jan 08, 2014 - 12:01:41
Jan 08, 2014 - 12:01:07
Jan 08, 2014 - 12:01:51
Jan 08, 2014 - 12:01:50
Jan 08, 2014 - 12:01:36
Jan 08, 2014 - 12:01:59
Jan 08, 2014 - 12:01:58
Jan 08, 2014 - 12:01:20
Jan 08, 2014 - 12:01:52
Jan 08, 2014 - 12:01:45
Jan 08, 2014 - 12:01:44
Jan 08, 2014 - 12:01:33
Jan 08, 2014 - 12:01:24
Jan 08, 2014 - 12:01:23
Jan 08, 2014 - 12:01:19
Jan 08, 2014 - 12:01:17
Jan 08, 2014 - 12:01:46
Jan 08, 2014 - 12:01:18
Jan 08, 2014 - 12:01:25
Jan 08, 2014 - 12:01:03
Jan 08, 2014 - 12:01:02
Jan 06, 2014 - 11:01:03
Jan 06, 2014 - 11:01:02
Jan 06, 2014 - 11:01:46
Jan 02, 2014 - 11:01:26
Jan 02, 2014 - 11:01:25
Nov 13, 2013 - 10:11:53
Aug 30, 2013 - 09:08:28
Aug 30, 2013 - 09:08:17
Aug 30, 2013 - 09:08:08
Aug 30, 2013 - 09:08:53
Aug 26, 2013 - 02:08:08
Aug 26, 2013 - 01:08:26
Aug 26, 2013 - 12:08:42
Aug 26, 2013 - 08:08:28
Aug 26, 2013 - 08:08:41
Aug 26, 2013 - 08:08:50
Aug 26, 2013 - 08:08:02
Aug 26, 2013 - 08:08:03
Aug 26, 2013 - 08:08:48
Aug 26, 2013 - 07:08:28
Aug 26, 2013 - 07:08:52
Aug 26, 2013 - 07:08:57
Aug 26, 2013 - 07:08:58
Aug 23, 2013 - 02:08:26
Aug 23, 2013 - 02:08:15
Aug 23, 2013 - 02:08:47
Aug 23, 2013 - 02:08:19
Aug 23, 2013 - 02:08:27
Aug 23, 2013 - 02:08:17
Aug 23, 2013 - 02:08:18
Aug 23, 2013 - 02:08:51
Aug 23, 2013 - 02:08:08
Aug 23, 2013 - 02:08:45
Aug 23, 2013 - 02:08:54
Aug 23, 2013 - 02:08:06
Aug 23, 2013 - 02:08:07
Aug 23, 2013 - 02:08:34
Aug 23, 2013 - 02:08:30
Aug 23, 2013 - 02:08:37
Aug 23, 2013 - 02:08:01
Aug 23, 2013 - 06:08:22
Aug 23, 2013 - 06:08:52
Aug 23, 2013 - 06:08:20
Aug 21, 2013 - 09:08:54
Aug 21, 2013 - 09:08:44
Aug 21, 2013 - 09:08:22
Aug 21, 2013 - 09:08:59
Aug 21, 2013 - 09:08:38
Aug 21, 2013 - 09:08:12
Aug 21, 2013 - 09:08:46
Aug 21, 2013 - 09:08:25
Aug 21, 2013 - 09:08:03
Aug 21, 2013 - 09:08:43
Aug 21, 2013 - 09:08:52
Aug 21, 2013 - 09:08:19
Aug 21, 2013 - 09:08:01
Aug 21, 2013 - 09:08:11
Aug 21, 2013 - 09:08:28
Aug 21, 2013 - 09:08:56
Aug 21, 2013 - 09:08:40
Aug 21, 2013 - 09:08:20
Aug 21, 2013 - 09:08:30
Aug 21, 2013 - 09:08:47
Aug 21, 2013 - 09:08:48
Aug 21, 2013 - 08:08:05
Aug 21, 2013 - 08:08:21
Aug 21, 2013 - 08:08:52
Aug 21, 2013 - 08:08:47
Aug 21, 2013 - 07:08:18
Aug 21, 2013 - 07:08:20
Aug 21, 2013 - 07:08:02
Aug 21, 2013 - 07:08:33
Aug 19, 2013 - 01:08:48
Aug 19, 2013 - 01:08:50
Aug 19, 2013 - 01:08:49
Aug 09, 2013 - 09:08:02
Aug 09, 2013 - 09:08:04
Aug 09, 2013 - 09:08:12
Aug 09, 2013 - 09:08:13
Aug 09, 2013 - 09:08:26
Aug 09, 2013 - 09:08:01
Aug 09, 2013 - 09:08:37
Aug 09, 2013 - 08:08:10
Aug 09, 2013 - 08:08:33
Aug 09, 2013 - 08:08:54
Aug 09, 2013 - 08:08:05
Aug 09, 2013 - 08:08:34
Aug 09, 2013 - 08:08:59
Aug 09, 2013 - 08:08:50
Aug 09, 2013 - 08:08:24
Aug 09, 2013 - 08:08:41
Aug 09, 2013 - 08:08:49
Aug 09, 2013 - 07:08:33
Aug 09, 2013 - 07:08:11
Aug 09, 2013 - 06:08:24
Aug 09, 2013 - 06:08:17
Aug 09, 2013 - 06:08:45
Aug 09, 2013 - 06:08:27
Aug 09, 2013 - 06:08:11
Aug 09, 2013 - 06:08:49
Aug 09, 2013 - 06:08:23
Aug 09, 2013 - 06:08:58
Aug 09, 2013 - 06:08:50
Aug 09, 2013 - 06:08:57
Aug 09, 2013 - 06:08:03
Aug 09, 2013 - 06:08:46
Aug 09, 2013 - 06:08:34
Aug 09, 2013 - 06:08:36
Aug 09, 2013 - 06:08:33
Aug 09, 2013 - 06:08:40
Aug 08, 2013 - 01:08:28
Aug 08, 2013 - 01:08:01
Aug 08, 2013 - 01:08:42
Aug 08, 2013 - 01:08:35
Aug 08, 2013 - 01:08:45
Aug 08, 2013 - 01:08:37
Aug 08, 2013 - 01:08:22
Aug 08, 2013 - 01:08:44
Aug 08, 2013 - 01:08:32
Aug 08, 2013 - 01:08:06
Aug 08, 2013 - 01:08:17
Aug 08, 2013 - 01:08:56
Aug 08, 2013 - 01:08:31
Aug 08, 2013 - 01:08:08
Aug 08, 2013 - 01:08:23
Aug 08, 2013 - 01:08:57
Aug 08, 2013 - 01:08:38
Aug 08, 2013 - 01:08:19
Aug 08, 2013 - 01:08:58
Aug 08, 2013 - 01:08:12
Aug 08, 2013 - 01:08:43
Aug 08, 2013 - 12:08:30
Aug 08, 2013 - 12:08:13
Aug 08, 2013 - 12:08:54
Aug 08, 2013 - 12:08:49
Aug 08, 2013 - 12:08:36
Aug 08, 2013 - 12:08:38
Aug 08, 2013 - 12:08:11
Aug 08, 2013 - 12:08:45
Aug 08, 2013 - 12:08:59
Aug 08, 2013 - 12:08:34
Aug 08, 2013 - 12:08:14
Aug 07, 2013 - 07:08:08
Aug 07, 2013 - 07:08:24
Aug 05, 2013 - 09:08:13
Aug 05, 2013 - 09:08:55
Aug 05, 2013 - 09:08:47
Aug 05, 2013 - 09:08:15
Aug 05, 2013 - 08:08:41
Aug 05, 2013 - 08:08:54
Aug 05, 2013 - 08:08:09
Aug 05, 2013 - 08:08:13
Aug 05, 2013 - 07:08:29
Aug 05, 2013 - 07:08:44
Aug 05, 2013 - 07:08:40
Aug 05, 2013 - 07:08:16
Aug 05, 2013 - 07:08:01
Aug 05, 2013 - 07:08:08
Aug 05, 2013 - 07:08:13
Aug 05, 2013 - 06:08:06
Aug 05, 2013 - 06:08:16
Aug 05, 2013 - 06:08:01
Aug 05, 2013 - 06:08:54
Aug 05, 2013 - 06:08:43
Aug 05, 2013 - 06:08:27
Aug 05, 2013 - 06:08:34
Aug 05, 2013 - 06:08:35
Aug 05, 2013 - 06:08:57
Aug 05, 2013 - 06:08:30
Aug 05, 2013 - 06:08:42
Aug 05, 2013 - 06:08:53
Aug 05, 2013 - 06:08:17
Aug 05, 2013 - 06:08:52
Aug 05, 2013 - 06:08:18
Aug 05, 2013 - 06:08:11
Aug 05, 2013 - 06:08:41
Aug 05, 2013 - 05:08:35
Aug 05, 2013 - 05:08:09
Aug 05, 2013 - 05:08:13
Aug 02, 2013 - 01:08:50
Aug 02, 2013 - 01:08:09
Aug 02, 2013 - 01:08:36
Aug 02, 2013 - 01:08:14
Aug 02, 2013 - 01:08:46
Aug 02, 2013 - 01:08:20
Aug 02, 2013 - 12:08:54
Aug 01, 2013 - 12:08:11
Aug 01, 2013 - 12:08:16
Aug 01, 2013 - 12:08:53
Aug 01, 2013 - 12:08:04
Aug 01, 2013 - 12:08:02
Aug 01, 2013 - 12:08:22
Aug 01, 2013 - 12:08:10
Aug 01, 2013 - 12:08:12
Aug 01, 2013 - 12:08:54
Aug 01, 2013 - 12:08:35
Aug 01, 2013 - 12:08:48
Aug 01, 2013 - 12:08:36
Aug 01, 2013 - 07:08:17
Aug 01, 2013 - 07:08:45
Aug 01, 2013 - 07:08:24
Aug 01, 2013 - 07:08:46
Aug 01, 2013 - 07:08:27
Aug 01, 2013 - 07:08:36
Aug 01, 2013 - 07:08:08
Aug 01, 2013 - 07:08:47
Aug 01, 2013 - 06:08:19
Aug 01, 2013 - 06:08:53
Aug 01, 2013 - 06:08:44
Aug 01, 2013 - 05:08:35
Jul 31, 2013 - 02:07:11
Jul 31, 2013 - 02:07:36
Jul 31, 2013 - 02:07:50
Jul 31, 2013 - 02:07:19
Jul 31, 2013 - 02:07:05
Jul 31, 2013 - 02:07:34
Jul 31, 2013 - 01:07:04
Jul 31, 2013 - 01:07:46
Jul 31, 2013 - 01:07:15
Jul 31, 2013 - 01:07:27
Jul 31, 2013 - 01:07:33
Jul 31, 2013 - 01:07:07
Jul 31, 2013 - 01:07:16
Jul 31, 2013 - 01:07:10
Jul 31, 2013 - 01:07:36
Jul 31, 2013 - 01:07:38
Jul 31, 2013 - 01:07:32
Jul 31, 2013 - 01:07:22
Jul 31, 2013 - 12:07:26
Jul 31, 2013 - 12:07:17
Jul 31, 2013 - 12:07:21
Jul 31, 2013 - 12:07:44
Jul 31, 2013 - 12:07:07
Jul 31, 2013 - 12:07:30
Jul 31, 2013 - 12:07:01
Jul 31, 2013 - 12:07:58
Jul 31, 2013 - 12:07:52
Jul 31, 2013 - 11:07:39
Jul 31, 2013 - 11:07:31
Jul 31, 2013 - 11:07:18
Jul 31, 2013 - 11:07:51
Jul 31, 2013 - 11:07:13
Jul 31, 2013 - 10:07:05
Jul 31, 2013 - 10:07:51
Jul 31, 2013 - 10:07:28
Jul 31, 2013 - 10:07:04
Jul 31, 2013 - 10:07:25
Jul 31, 2013 - 10:07:42
Jul 31, 2013 - 10:07:44
Jul 31, 2013 - 10:07:24
Jul 31, 2013 - 10:07:27
Jul 26, 2013 - 10:07:35
Jul 26, 2013 - 10:07:54
Jul 26, 2013 - 10:07:17
