Tools
Parts
- High-Pressure Seal Kit #11451
- High-Pressure Seal with O-ring #11024 (included in kit)
- Hoop #11018 (included in kit)
- High-Vacuum Grease #11447 (included in kit)
- HP Cylinder #14766
- Spacer Tube #11521
- Low-Pressure Poppet Basket #11520
- AS Low-Pressure Poppet #11526
- Check Valve #14767
- -031 O-ring #11679-031
- -035 O-ring #11679-035
- AS HP Endcap #11529
- 1"-14 Grade 8 Nut #11672
- Blue Goop #11111
- O-ring Lube #13969
Always make sure all high-pressure water has been removed from pump by following machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
Remove HP cylinders and check valves from intensifier. Clean cylinders and check valves thoroughly, following standard procedures.
Scotch-Brite, or similar abrasive pad, can be used on sealing faces of cylinder and check valve to clean marking and/or galling.
Place HP cylinder on seal installation spacer tool, taper side down
Apply light coat of high vacuum grease to both shoulders of spacer tube
Insert spacer tube into cylinder with LP poppet end down
Place locator tool on cylinder
Place sleeve in locator tool with taper end up
Apply light coat of high vacuum grease to red o-ring
Roll red o-ring into groove on HP seal
Insert assembled HP seal into sleeve with red o-ring down towards cylinder
Press HP seal into cylinder using non-stepped end of push tool
Hold down sleeve while inserting HP seal to ensure seal doesn't catch on edge of HP cylinder
Place hoop in sleeve with sharp edge of hoop down towards HP cylinder
Seat hoop in HP cylinder using non-stepped end of push tool and dead blow hammer
Hold down sleeve while seating hoop to ensure hoop doesn't catch on edge of HP cylinder
Remove locator tool, sleeve, and push tool
Apply a light coat of blue goop to outer face of inset on end of HP cylinder
Flip cylinder over and remove seal installation spacer tool
Insert LP poppet in LP poppet basket so stem of poppet goes through center hole in basket
Make sure LP poppet can freely move in LP poppet basket
Insert LP poppet and LP poppet basket into spacer tube in HP cylinder
Place seal installation spacer tool on end of HP cylinder with step side down
Place mounting cradle on bottom studs of intensifier with tabs toward outside of intensifier
Push HP cylinder onto plunger using mounting cradle as a guide and seal installation spacer tool as a push tool
Remove seal installation spacer tool, taking care to that LP poppet stays in LP poppet basket
Apply light coat of o-ring lube to -035 and -031 o-rings for check valve
Place -031 and -035 o-rings into grooves on check valve
Apply light coat of blue goop to tapered (sealing) face of check valve
Apply light coat of blue goop to bottom step of check valve
Insert check valve into HP endcap
Slide HP endcap with check valve onto intensifier studs
Push HP endcap against HP cylinder and align tabs of mounting cradle so cradle supports HP endcap
The mounting cradle is used to ensure proper alignment between HP cylinder an HP endcap during torquing
Thread and hand-tighten nuts onto studs using a cross pattern
Torque nuts using a cross pattern according to the following directions
Use numbers in picture as a guide for location number found in included table for torquing procedure
Torque each nut in torque order found in table to each torque value prior to stepping to next value
Continue with HP poppet installation and standard start-up procedures
Cancel: I did not complete this guide.
One other person completed this guide.
