Skip to main content
Introduction
  1. Remove all the components from the static end of the  high-pressure cylinder with the proper tools. Clean all Blue Goop off the high-pressure cylinder with isopropyl alcohol or a similar cleaning agent. Apply high vacuum grease to the O-ring.
  2. Slide the O-ring onto the groove of the high-pressure seal. Put the high-pressure seal into the end of the high-pressure cylinder. Put the static back-up behind the high-pressure seal.
    • Slide the O-ring onto the groove of the high-pressure seal.
    • Put the high-pressure seal into the end of the high-pressure cylinder.
    • Put the static back-up behind the high-pressure seal.
  3. Apply Blue Goop to both ends of the high-pressure cylinder threads.
    • Apply Blue Goop to both ends of the high-pressure cylinder threads.
    • Reassemble the high-pressure cylinder into the intensifier assembly.
Finish Line
One other person completed this guide.
Adam Dumas
36 Guides authored
0 Comments
Add Comment
