Introduction
Remove the old components from the plunger end of the high-pressure cylinder with the proper tooling.
Remove the cylinder liner from the high-pressure cylinder.
Clean the high-pressure cylinder threads of all Blue Goop with isopropyl alcohol or similar cleaning agent.
Inspect the inside of the high-pressure cylinder, if scratches/galling have occurred, use Scotch Brite or a similar abrasive pad and roll back and forth to each end of the high-pressure cylinder to remove blemishes.
Repeat the process (if needed) with 1500 grit abrasive to polish the inside of the bore.
Apply high pressure grease to the O-ring.
Slide the O-ring onto the groove of the high-pressure seal.
Insert the high-pressure seal into the dynamic end of the high-pressue cylinder.
Insert the dynamic seal back-up behind the high-pressure seal.
Insert the brass packing follower into the high-pressure cylinder, behind the dynamic seal back-up.
Continue to static seal assembly. If complete, reassemble the high-pressure cylinder into the intensifier assembly.
