Site Navigation
Your Account
Choose Language
Introduction
Always make sure all high-pressure water has been removed from the valve by following the machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
  • Always make sure all high-pressure water has been removed from the valve by following the machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
  • Turn the on/off valve ON to raise the needle from the seat.
Add Comment
Components can be replaced with the valve body in the mounting collar.
  • Components can be replaced with the valve body in the mounting collar.
  • Loosen the adapter from the valve body using a 1" and 13/16" wrench.
  • Unthread the adapter from the valve body.
Add Comment
Add Comment
  • Remove all the valve components using the included dowel.
  • Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol before replacing the components.
  • Inspect the top and bottom of the bore for cracks/blemishes. If excessive wear or cracks are visible, replace the valve body.
Add Comment
Add Comment
  • Put the needle point at the top of the valve body.
  • Use the dowel to push the needle into the valve body until the needle bearing bottoms out.
Add Comment
Add Comment
  • Clean the adapter of all Blue Goop with isopropyl alcohol.
  • Reapple Blue Goop to the threads and to the top of the adapter.
  • Put seat into the adapter with flat the side towards the adapter.
Add Comment
  • Apply Blue Goop to the top of the seat.
  • Turn the air to the actuator ON.
  • Thread the adapter into the valve body.
Add Comment
  • Tighten adapter into valve body using a 1" and 13/16" wrench.
  • Turn the air to the actuator OFF.
Add Comment
  • Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head.
  • Reinstall the cutting head and continue the cutting process.
Add Comment
Finish Line
Adam Dumas
36 Guides authored
0 Comments
Add Comment
