Introduction
Parts
- On/Off Valve Repair Kit #11279
- O-ring #11145 (included in kit)
- Poppet Needle #11275 (included in kit)
- Poppet Seat #11141 (included in kit)
- Bushing Stem #11273 (included in kit)
- High-Pressure Valve Seal #11276 (included in kit)
- Back-up Ring #11274 (included in kit)
- Actuator #12129
- Nozzle Tube #11358-4
- Valve Body #11272
- Blue Goop #11111
- Isopropyl Alcohol
Turn OFF all water pressure to the on/off valve.
Turn the on/off valve ON to raise the poppet needle from poppet seat.
Unthread the nozzle tube from the valve body using a 3/4" and 7/8" wrench.
Turn the air to the actuator OFF at the controls.
Disconnect the air tube from the actuator.
Unthread the actuator from the valve body using 1-1/8" wrench.
Remove the old valve components from the valve body with the included dowel.
Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol or a similar cleaning agent before replacing the components.
Put the bushing stem onto the poppet stem.
With the O-ring towards the bushing stem, slide the high-pressure valve seal onto the poppet needle behind the bushing stem.
Apply a high-pressure lubricant or similar (11136) to the outside diameter of the high-pressure valve seal.
Put the back-up ring with the concave side towards the seal then slide on the poppet needle behind the high-pressure seal.
Put the poppet needle, with the point down, at the top of the valve body.
Use the dowel to push the poppet needle down until the back-up ring is flush with the top of the bore.
Apply Blue Goop to the top threads of the valve body.
Thread (hand tighten) the actuator onto the top of the valve body.
Reconnect the air line to the top of the actuator.
Turn the actuator air pressure ON to relieve the pressure from the poppet needle.
Thoroughly clean the nozzle tube of all Blue Goop.
Reapply Blue Goop to the threads of the nozzle tube.
Thread the nozzle tube into the bottom of the valve body.
Tighten the nozzle tube to the valve using a 3/4" and 7/8" wrench.
Turn the air to the actuator OFF to set the poppet needle into the poppet seat.
Apply water pressure to the valve assembly to verify that there are no leaks.
Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head.
Re-install the cutting head and continue the cutting process.
Cancel: I did not complete this guide.
2 other people completed this guide.
