Introduction
Tools
Parts
- On/Off Valve Repair Kit #13687
- O-ring #11145 (included in kit)
- Poppet Seat #11141 (included in kit)
- Bushing Stem #11273 (included in kit)
- High-Pressure Valve Seal #11276 (included in kit)
- Back-up Ring #11274 (included in kit)
- Actuator #12129
- Valve Body #11272
- Nozzle Tube #11358-4
- Blue Goop #11111
- Isopropyl Alcohol
Turn OFF all water pressure to the on/off valve
Turn the on/off valve ON to raise the poppet stem from the high-pressure seat.
Unthread the nozzle tube from the valve body using a 3/4" and 7/8" wrench.
Turn the air to the actuator OFF at the controls
Disconnect the air tube from the actuator.
Unthread the actuator from the valve body using 1-1/8" wrench.
Remove the old valve components from the valve body with the included dowel.
Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol or a similar cleaning agent before replacing the components.
Put the bushing stem onto the poppet stem.
With the O-ring down, slide the high-pressure valve seal onto the poppet stem behind the bushing stem.
Apply a high-pressure lubricant or similar (11136) to the outside diameter of the high-pressure valve seal.
Put the back-up ring with the concave side towards the high-pressure seal on the poppet stem behind the high-pressure seal.
Put the poppet stem, with the point down, at the top of the valve body.
Use the dowel to push the poppet stem down until the back-up ring is flush with the top of the bore.
Turn the air to the actuator ON to relieve the pressure from the poppet stem.
Thoroughly clean the nozzle tube of all the Blue Goop.
Reapply Blue Goop to the threads of the nozzle tube.
Thread the nozzle tube into the bottom of the valve body.
Tighten the nozzle tube to the valve body using 3/4" and 7/8" wrench.
Turn the air to the actuator OFF to set the poppet stem into the high-pressure seat.
Apply water pressure to the valve assembly to verify there are no leaks.
Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head.
Reinstall the cutting head and continue the cutting process.
