Parts
- 1/4" Minor Swivel Repair Kit #12864
- Seal, 1/4" Swivel #12867 (included in kit)
- High-Pressure O-ring "Red" #12662-008 (Included in kit)
- Back-up, 1/4" F-F Swivel #12872 (included in kit)
- Wiper #12875 (included in kit)
- Thrust Bearing, #12181 (included in kit)
- Thrust Washer #12874 (included in kit)
- 4-40 X 1.25 SHCS (included in kit) × 2
- High-Vacuum Grease #11447 (included in kit)
- Dowel
- Swivel Nut #12868
- Swivel Housing, Seal Half #12871
- Swivel Housing with Bearing #12870
- Swivel Shaft, 1/4 F-F #12869
- -123 O-ring #11679-123
- 1/4" High-pressure Collar #13157-60-4 × 2
- 1/4" High-Pressure Gland #13158-60-4 × 2
- Lithium Grease
- O-ring Lube #13969
- Blue Goop #11111
Loosen high-pressure gland from swivel nut with a 5/8" and 11/16" wrench.
Unthread the high-pressure gland from the swivel nut.
Loosen high-pressure gland from base of swivel housing with a 1-1/8" and 5/8" wrench.
Unthread the high-pressure gland from the base of the swivel housing.
Loosen the bearing half of the swivel housing from the seal half of housing with two 1-1/8" wrenches.
Unthread the bearing half of the swivel housing from the seal half of the swivel housing.
Loosen the swivel nut from the swivel shaft with a 3/4" and 11/16" wrench.
Unthread the swivel nut from the swivel shaft.
Remove the thrust washers and the thrust bearing from the swivel shaft.
Clean the swivel of all Blue Goop and lithium grease with isopropyl alcohol or a similar cleaning agent.
Clean the swivel nut of all Blue Goop with isopropyl alcohol or a similar cleaning agent.
Remove the wiper from the top of the bearing half of the swivel housing with a pick.
Clean all Blue Goop from the bearing half of the swivel housing with isopropyl alcohol or a similar cleaning agent.
Remove the O-ring from the outside of the seal half of the swivel housing.
Remove the back-up bearing from the seal half of the swivel housing.
Remove the high-pressure seal from the inside of the seal half of the swivel housing with a pick.
Clean the seal half of the swivel housing of all Blue Goop and any extra lubricants with isopropyl alcohol or a similar cleaning agent.
Apply high vacuum grease to the high-pressure seal.
Put high-pressure seal, with the O-ring first, into the bore of the seal half of the swivel housing using a dowel.
Place the back-up bearing into the seal half of the swivel housing with the small stepped end down.
Apply a layer of O-ring lube to the O-ring.
Place the O-ring onto the seal half of the swivel housing in the groove.
Apply lithium grease to the base of the swivel shaft.
Place the first thrust washer onto the swivel shaft.
Apply lithium grease to the top of the thrust washer.
Place the thrust bearing onto the swivel shaft.
Apply lithium grease to the top of the thrust bearing.
Put the second thrust washer onto the swivel shaft.
Put the wiper into the top of the bearing half of the swivel housing with the tapered end down.
Apply Blue Goop to threads of swivel shaft
Put swivel shaft ,threads first, through bottom (thread side) of bearing half of swivel housing
Thread swivel nut onto swivel shaft
Tighten swivel nut to swivel shaft
Apply Blue Goop to threads of bearing half of swivel housing
Apply high vacuum grease to stem of swivel shaft
Thread bearing half of swivel housing into seal half of swivel housing.
Tighten bearing half of swivel housing to seal half of swivel housing with two 1-1/8" wrenches.
Clean high-pressure gland of all Blue Goop.
Apply Blue Goop to threads of high-pressure gland.
Thread high-pressure gland into seal half of swivel housing.
Tighten high-pressure gland into seal half of swivel housing with 1-1/8" and 5/8" wrench.
Clean high-pressure gland of all Blue Goop with isopropyl alcohol
Thread high-pressure gland into swivel nut.
Cancel: I did not complete this guide.
2 other people completed this guide.
