Site Navigation
Your Account
Choose Language
Image 1/3: Using a 5/64" Allen Wrench, remove the retainer cap from the bottom of the actuator. Image 2/3: Place the actuator in a bench vise.  Tighten the vise enough to slightly compress the actuator springs. Image 3/3: Caution: the actuator assembly contains high-force springs under compression.
  • Remove the air fitting from the top of the actuator
  • Using a 5/64" Allen Wrench, remove the retainer cap from the bottom of the actuator.
  • Place the actuator in a bench vise. Tighten the vise enough to slightly compress the actuator springs.
  • Caution: the actuator assembly contains high-force springs under compression.
  • Using the ratcheting snap ring pliers, compress and remove the snap ring that secures the actuator cap into the housing.
  • Carefully take the actuator out of the vise. All of the internal actuator components can now be removed.
Add Comment
Image 1/1: Inspect and lubricate all O-rings.
  • After cleaning and inspecting, replace at least the exhaust vent, two O-rings on the actuator shaft, poly seal, and all six springs.
  • Inspect and lubricate all O-rings.
  • Install new O-rings on both ends of the shaft. Note the O-ring sizes and locations.
  • Install the Poly Seal on the actuator piston with the "thick" part of the seal facing "down" (pointing away from the springs).
  • Install the O-ring on the bearing cap.
Add Comment
Image 1/2: Twist the actuator cap until the four screw holes line up with the holes in the retainer. Image 2/2: Place the actuator in a bench vise.  Tighten the vise enough to slightly compress the actuator springs.
  • After all the internal components have been re-installed, place the retainer cap with the tabs in the slots on the housing.
  • Twist the actuator cap until the four screw holes line up with the holes in the retainer.
  • Using the ratcheting snap ring pliers, compress and replace the snap ring that secures the actuator cap into the housing.
  • Remove the actuator from the vise. Use a 5/64 Allen wrench to tighten the four screws that hold the retainer to the actuator cap.
Add Comment
Finish Line
One other person completed this guide.
Curtis Boettjer
1 Guide authored
0 Comments
Add Comment
