Site Navigation
Your Account
Choose Language
Introduction
Remove all the components from the static end of the  high-pressure cylinder with the proper tools. Clean all Blue Goop off the high-pressure cylinder with isopropyl alcohol or a similar cleaning agent. Apply high vacuum grease to the O-ring.
Add Comment
Slide the O-ring onto the groove of the high-pressure seal. Put the high-pressure seal into the end of the high-pressure cylinder. Put the static back-up behind the high-pressure seal.
  • Slide the O-ring onto the groove of the high-pressure seal.
  • Put the high-pressure seal into the end of the high-pressure cylinder.
  • Put the static back-up behind the high-pressure seal.
Add Comment
Apply Blue Goop to both ends of the high-pressure cylinder threads.
  • Apply Blue Goop to both ends of the high-pressure cylinder threads.
  • Reassemble the high-pressure cylinder into the intensifier assembly.
Add Comment
Finish Line
One other person completed this guide.
Adam Dumas
36 Guides authored
0 Comments
Add Comment
