Site Navigation
Your Account
Choose Language
Introduction
Image 1/3: Remove the  [http://www.accustream.com/all-products/11605.html|cylinder liner] from the high-pressure cylinder. Image 2/3: Clean the high-pressure cylinder threads of all [http://www.accustream.com/all-products/11111.html|Blue Goop] with isopropyl alcohol or similar cleaning agent. Image 3/3: Clean the high-pressure cylinder threads of all [http://www.accustream.com/all-products/11111.html|Blue Goop] with isopropyl alcohol or similar cleaning agent.
  • Remove the old components from the plunger end of the high-pressure cylinder with the proper tooling.
  • Remove the cylinder liner from the high-pressure cylinder.
  • Clean the high-pressure cylinder threads of all Blue Goop with isopropyl alcohol or similar cleaning agent.
Add Comment
Image 1/3: Repeat the process (if needed) with 1500 grit abrasive to polish the inside of the bore. Image 2/3: Apply [http://www.accustream.com/all-products/11447.html|high pressure grease] to the O-ring. Image 3/3: Apply [http://www.accustream.com/all-products/11447.html|high pressure grease] to the O-ring.
  • Inspect the inside of the high-pressure cylinder, if scratches/galling have occurred, use Scotch Brite or a similar abrasive pad and roll back and forth to each end of the high-pressure cylinder to remove blemishes.
  • Repeat the process (if needed) with 1500 grit abrasive to polish the inside of the bore.
  • Apply high pressure grease to the O-ring.
Add Comment
Image 1/3: Put the high-pressure seal into the  dynamic end of the high-pressue cylinder. Image 2/3: Put the dynamic seal back-up behind the high-pressure seal. Image 3/3: Put the dynamic seal back-up behind the high-pressure seal.
  • Slide the O-ring onto the groove of the high-pressure seal.
  • Put the high-pressure seal into the dynamic end of the high-pressue cylinder.
  • Put the dynamic seal back-up behind the high-pressure seal.
Add Comment
Image 1/1: Continue to [guide|31|static seal] assembly. If complete, reassemble the high-pressure cylinder into the intensifier assembly.
  • Put the brass packing follower into the high-pressure cylinder, behind the dynamic seal back-up.
  • Continue to static seal assembly. If complete, reassemble the high-pressure cylinder into the intensifier assembly.
Add Comment
Finish Line
4 other people completed this guide.
Adam Dumas
36 Guides authored
0 Comments
Add Comment
