Site Navigation
Your Account
Choose Language
Image 1/3: Unthread the high-pressure gland nut from the swivel collar. Image 2/3: Clean the high-pressure gland nut and the high-pressure tubing cone with isopropyl alcohol or a similar cleaning agent. Image 3/3: Clean the high-pressure gland nut and the high-pressure tubing cone with isopropyl alcohol or a similar cleaning agent.
  • Loosen the high-pressure gland nut from swivel collar with 5/8" and 3/4" wrench.
  • Unthread the high-pressure gland nut from the swivel collar.
  • Clean the high-pressure gland nut and the high-pressure tubing cone with isopropyl alcohol or a similar cleaning agent.
Add Comment
Image 1/3: Loosen the high-pressure gland from the coupling with 1-1/16" and 5/8" wrench. Image 2/3: Unthread the high-pressure gland at the top of the swivel shaft from the coupling. Image 3/3: Unthread the high-pressure gland at the top of the swivel shaft from the coupling.
  • Remove the swivel collar from the swivel housing.
  • Loosen the high-pressure gland from the coupling with 1-1/16" and 5/8" wrench.
  • Unthread the high-pressure gland at the top of the swivel shaft from the coupling.
Add Comment
Image 1/3: Remove the high-pressure gland and collet from the swivel shaft. Image 2/3: Clean the high-pressure gland of all Blue Goop with isopropyl alcohol. Image 3/3: Clean the high-pressure gland of all Blue Goop with isopropyl alcohol.
  • Uthread the high-pressure collar from the threads of the swivel shaft.
  • Remove the high-pressure gland and collet from the swivel shaft.
  • Clean the high-pressure gland of all Blue Goop with isopropyl alcohol.
Add Comment
Image 1/3: Unthread bearing half from seal half of the swivel housing. Image 2/3: Remove the swivel shaft from the bearing half of the swivel housing by pushing down through the wiper. Image 3/3: When removing the swivel shaft, the top thrust washer could stick to the inside top of the bearing half.
  • Use two 3/4" wrenches to separate the bearing half and seal half of the swivel housing.
  • Unthread bearing half from seal half of the swivel housing.
  • Remove the swivel shaft from the bearing half of the swivel housing by pushing down through the wiper.
    • When removing the swivel shaft, the top thrust washer could stick to the inside top of the bearing half.
Add Comment
Image 1/3: Remove the bearing back-up from the seal half of the swivel housing. Image 2/3: Remove the high pressure seal assembly from the seal half of the swivel housing with a pick. Image 3/3: Be sure to not scratch the ID of the swivel housing with a pick.
  • Remove the thrust washers and the thrust bearing from the swivel shaft.
  • Remove the bearing back-up from the seal half of the swivel housing.
  • Remove the high pressure seal assembly from the seal half of the swivel housing with a pick.
    • Be sure to not scratch the ID of the swivel housing with a pick.
Add Comment
Image 1/3: Remove the O-ring from the bearing half of the swivel housing. Image 2/3: Remove the wiper from the top of the bearing half of the swivel housing with a pick. Image 3/3: Remove the wiper from the top of the bearing half of the swivel housing with a pick.
  • Clean the seal half of the swivel housing of all Blue Goop with isopropyl alcohol or a similar cleaning agent.
  • Remove the O-ring from the bearing half of the swivel housing.
  • Remove the wiper from the top of the bearing half of the swivel housing with a pick.
Add Comment
Image 1/3: Clean the bearing half of the swivel housing with isopropyl alcohol or a  similar cleaning agent. Image 2/3: Apply a layer of [http://www.accustream.com/all-products/11447.html|high vacuum grease] into the cavity of the seal half of the swivel housing. Image 3/3: Apply a layer of [http://www.accustream.com/all-products/11447.html|high vacuum grease] into the cavity of the seal half of the swivel housing.
  • Remove the swivel bearing from the bearing half of the swivel housing by pushing a .300-.360 gauge pin through the bearing half.
  • Clean the bearing half of the swivel housing with isopropyl alcohol or a similar cleaning agent.
  • Apply a layer of high vacuum grease into the cavity of the seal half of the swivel housing.
Add Comment
Image 1/3: Put the high-pressure seal from the kit, with the O-ring down, into the cavity of the seal half of the swivel housing. Image 2/3: Apply a layer of [http://www.accustream.com/all-products/11111.html|Blue Goop] to the threads of the seal half of the swivel housing. Image 3/3: Apply a layer of [http://www.accustream.com/all-products/11111.html|Blue Goop] to the threads of the seal half of the swivel housing.
  • Apply a layer of high vacuum grease to the high-pressure seal from the kit.
  • Put the high-pressure seal from the kit, with the O-ring down, into the cavity of the seal half of the swivel housing.
  • Apply a layer of Blue Goop to the threads of the seal half of the swivel housing.
Add Comment
Image 1/3: Be sure that the swivel bearing is flush with the bottom of the cavity of the bearing half of the swivel housing. Image 2/3: Clean the swivel shaft of all lithium grease and Blue Goop with isopropyl alcohol or a similar cleaning agent. Image 3/3: Clean the swivel shaft of all lithium grease and Blue Goop with isopropyl alcohol or a similar cleaning agent.
  • Put the bearing back-up into the seal half of the swivel housing on the top of the high-pressure seal with a .300-.360 gauge pin until it bottoms out.
  • Be sure that the swivel bearing is flush with the bottom of the cavity of the bearing half of the swivel housing.
  • Clean the swivel shaft of all lithium grease and Blue Goop with isopropyl alcohol or a similar cleaning agent.
Add Comment
Image 1/3: Put the first thrust washer from the kit onto the swivel shaft. Image 2/3: Apply lithium grease to the top of the first thrust washer. Image 3/3: Apply lithium grease to the top of the first thrust washer.
  • Apply lithium grease to the shelf of the swivel shaft.
  • Put the first thrust washer from the kit onto the swivel shaft.
  • Apply lithium grease to the top of the first thrust washer.
Add Comment
Image 1/3: Apply lithium grease to the top of the thrust bearing. Image 2/3: Put the second thrust washer onto the swivel shaft. Image 3/3: Put the second thrust washer onto the swivel shaft.
  • Put the thrust bearing onto the swivel shaft.
  • Apply lithium grease to the top of the thrust bearing.
  • Put the second thrust washer onto the swivel shaft.
Add Comment
Image 1/3: Apply high vacuum grease to the short end of the swivel shaft. Image 2/3: Put the back-up bearing into the top of the seal half of the swivel housing. Image 3/3: Put the back-up bearing into the top of the seal half of the swivel housing.
  • Apply lithium grease to the top of the thrust washer.
  • Apply high vacuum grease to the short end of the swivel shaft.
  • Put the back-up bearing into the top of the seal half of the swivel housing.
Add Comment
Image 1/3: Thread the bearing half of the swivel housing onto the seal half of the swivel housing. Image 2/3: Tighten both seal half and bearing half of the swivel housing using two 3/4" wrenches. Image 3/3: Tighten both seal half and bearing half of the swivel housing using two 3/4" wrenches.
  • Put the short end of the swivel shaft into the back-up bearing until it bottoms out.
  • Thread the bearing half of the swivel housing onto the seal half of the swivel housing.
  • Tighten both seal half and bearing half of the swivel housing using two 3/4" wrenches.
Add Comment
Image 1/3: Put the O-ring over the swivel shaft and into the groove of the swivel body. Image 2/3: Put the swivel housing into the swivel collar with the high-pressure inlet hole facing through the collar hole. Image 3/3: Put the swivel housing into the swivel collar with the high-pressure inlet hole facing through the collar hole.
  • Put the wiper over the swivel shaft and down into the top of the bearing half of the swivel housing.
  • Put the O-ring over the swivel shaft and into the groove of the swivel body.
  • Put the swivel housing into the swivel collar with the high-pressure inlet hole facing through the collar hole.
Add Comment
Image 1/3: Thread the high-pressure gland nut into the swivel collar. Image 2/3: Tighten the high-pressure gland nut with 3/4" and 5/8" wrench. Image 3/3: Tighten the high-pressure gland nut with 3/4" and 5/8" wrench.
  • Apply Blue Goop to the high-pressure gland nut threads.
  • Thread the high-pressure gland nut into the swivel collar.
  • Tighten the high-pressure gland nut with 3/4" and 5/8" wrench.
Add Comment
Image 1/3: Put the collet with the tapered side down into the high-pressure gland nut. Image 2/3: Apply Blue Goop to the swivel shaft threads. Image 3/3: Apply Blue Goop to the swivel shaft threads.
  • Put the collet with the tapered side down into the high-pressure gland nut.
  • Apply Blue Goop to the swivel shaft threads.
Add Comment
Image 1/3: Thread on the collar to the bottom of the threads of the swivel shaft. Image 2/3: Thread the high-pressure gland into the coupler. Image 3/3: Thread the high-pressure gland into the coupler.
  • Slide the high-pressure gland with the collet onto the swivel shaft.
  • Thread on the collar to the bottom of the threads of the swivel shaft.
  • Thread the high-pressure gland into the coupler.
Add Comment
Image 1/1:
  • Tighten the high-pressure gland into the coupler with 1-1/16" and 5/8" wrench.
Add Comment
Finish Line
Adam Dumas
36 Guides authored
0 Comments
Add Comment
