Site Navigation
Your Account
Choose Language
Image 1/2: Turn OFF all water pressure to the on/off valve. Image 2/2: Turn the on/off valve ON to raise the  [http://www.accustream.com/waterjet-parts/flow/flow-on-off-valve/insta-2-valve-parts/11275.html|poppet needle] from [http://www.accustream.com/all-products/11141.html|poppet seat].
  • Always make sure all high-pressure water has been removed from the valve by following the machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
  • Turn the on/off valve ON to raise the poppet needle from poppet seat.
Add Comment
Image 1/2: Unthread the [http://www.accustream.com/all-products/11358-4.html|nozzle tube] from the valve body using a 3/4" and 7/8" wrench. Image 2/2: Unthread the [http://www.accustream.com/all-products/11358-4.html|nozzle tube] from the valve body using a 3/4" and 7/8" wrench.
  • The valve kit components can be replaced with the valve body in the mounting collar.
  • Unthread the nozzle tube from the valve body using a 3/4" and 7/8" wrench.
Add Comment
Image 1/3: Disconnect the air tube from the actuator. Image 2/3: Unthread the actuator from the valve body using 1-1/8" wrench. Image 3/3: Unthread the actuator from the valve body using 1-1/8" wrench.
  • Turn the air to the actuator OFF at the controls.
  • Disconnect the air tube from the actuator.
  • Unthread the actuator from the valve body using 1-1/8" wrench.
Add Comment
Image 1/3: Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol or a similar cleaning agent before replacing the components. Image 2/3: Visually inspect the top and bottom of the bore for cracks/blemishes.  If excessive wear or cracks are visible, replace the [http://www.accustream.com/all-products/11272.html|valve body]. Image 3/3: Visually inspect the top and bottom of the bore for cracks/blemishes.  If excessive wear or cracks are visible, replace the [http://www.accustream.com/all-products/11272.html|valve body].
  • Remove the old valve components from the valve body with the included dowel.
  • Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol or a similar cleaning agent before replacing the components.
  • Visually inspect the top and bottom of the bore for cracks/blemishes. If excessive wear or cracks are visible, replace the valve body.
Add Comment
Image 1/3: With the O-ring towards the bushing stem, slide the  [http://www.accustream.com/all-products/11276.html|high-pressure valve seal] onto the poppet needle behind the bushing stem. Image 2/3: Apply a high-pressure lubricant or similar ([http://www.accustream.com/all-products/11136.html|11136]) to the  outside diameter of the high-pressure valve seal. Image 3/3: Apply a high-pressure lubricant or similar ([http://www.accustream.com/all-products/11136.html|11136]) to the  outside diameter of the high-pressure valve seal.
  • Put the bushing stem onto the poppet stem.
  • With the O-ring towards the bushing stem, slide the high-pressure valve seal onto the poppet needle behind the bushing stem.
  • Apply a high-pressure lubricant or similar (11136) to the outside diameter of the high-pressure valve seal.
Add Comment
Image 1/3: Put the poppet needle, with the point down, at the top of the valve body. Image 2/3: Use the dowel to push the poppet needle down until the back-up ring is flush with the top of the bore. Image 3/3: Use the dowel to push the poppet needle down until the back-up ring is flush with the top of the bore.
  • Put the back-up ring with the concave side towards the seal then slide on the poppet needle behind the high-pressure seal.
  • Put the poppet needle, with the point down, at the top of the valve body.
  • Use the dowel to push the poppet needle down until the back-up ring is flush with the top of the bore.
Add Comment
Image 1/3: Put the poppet seat at the bottom of the valve body. Image 2/3: Put the  [http://www.accustream.com/all-products/11145.html|O-ring] behind the poppet seat so it is held in place. Image 3/3: Put the  [http://www.accustream.com/all-products/11145.html|O-ring] behind the poppet seat so it is held in place.
  • Apply Blue Goop to all surfaces of the poppet seat.
  • Put the poppet seat at the bottom of the valve body.
  • Put the O-ring behind the poppet seat so it is held in place.
Add Comment
Image 1/3: Thread (hand tighten) the actuator onto the top of the valve body. Image 2/3: Reconnect the air line to the top of the actuator. Image 3/3: Reconnect the air line to the top of the actuator.
  • Apply Blue Goop to the top threads of the valve body.
  • Thread (hand tighten) the actuator onto the top of the valve body.
  • Reconnect the air line to the top of the actuator.
Add Comment
Image 1/3: Thoroughly clean the nozzle tube of all Blue Goop. Image 2/3: Reapply Blue Goop to the threads of the nozzle tube. Image 3/3: Reapply Blue Goop to the threads of the nozzle tube.
  • Turn the actuator air pressure ON to relieve the pressure from the poppet needle.
  • Thoroughly clean the nozzle tube of all Blue Goop.
  • Reapply Blue Goop to the threads of the nozzle tube.
Add Comment
Image 1/3: Tighten the nozzle tube to the valve using a 3/4" and 7/8" wrench. Image 2/3: Turn the air to the actuator OFF to set the poppet needle into the poppet seat. Image 3/3: Turn the air to the actuator OFF to set the poppet needle into the poppet seat.
  • Thread the nozzle tube into the bottom of the valve body.
  • Tighten the nozzle tube to the valve using a 3/4" and 7/8" wrench.
  • Turn the air to the actuator OFF to set the poppet needle into the poppet seat.
Add Comment
Image 1/3: Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head. Image 2/3: Re-install the cutting head and continue the cutting process. Image 3/3: Re-install the cutting head and continue the cutting process.
  • Apply water pressure to the valve assembly to verify that there are no leaks.
  • Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head.
  • Re-install the cutting head and continue the cutting process.
Add Comment
Finish Line
2 other people completed this guide.
Adam Dumas
36 Guides authored
0 Comments
Add Comment
