Introduction
Parts
- On/Off Valve Repair Kit #11146
- Poppet Stem #11140 (Included in Kit)
- O-ring #11145 (included in kit)
- Poppet Seat #11141 (included in kit)
- High-Pressure Valve Seal #11142 (Included in Kit)
- Back-up Ring #11143 (included in kit)
- Actuator #12128
- Valve Body #13380
- Nozzle Tube #11358-4
- Blue Goop #11111
- Isopropyl Alcohol
Always make sure all high-pressure water has been removed from the valve by following the machine manufacturers' safety instructions. Failure to do so can cause severe injury or death.
Turn OFF all water pressure to the on/off valve
Turn the on/off valve ON to raise the poppet stem from the poppet seat.
The valve kit components can be replaced with the valve body in the mounting collar.
Unthread the nozzle tube from the valve body using 3/4" and 7/8" wrench.
Remove the old valve components from the valve body with the included dowel.
Thoroughly clean the interior/exterior of the valve body with isopropyl alcohol or a similar cleaning agent before replacing the components.
Visually inspect the top and bottom of the bore for cracks/blemishes. If excessive wear or cracks are visible, replace the valve body.
With the O-ring towards the point of the needle, slide the high-pressure valve seal on to the poppet stem.
Apply a high-pressure lubricant or similar (11136) to the outside diameter of the high-pressure valve seal.
Slide the back-up ring on to the poppet stem behind the high-pressure valve seal.
Thread (hand tighten) the actuator on top of the valve body.
Reconnect the air line to the top of the actuator.
Turn the air to the actuator ON to relieve the pressure from the poppet stem.
Thoroughly clean the nozzle tube of all the Blue Goop.
Reapply Blue Goop to the top of the nozzle tube threads.
Thread the nozzle tube into the bottom of the valve body.
Tighten the nozzle tube to the valve using 3/4" and 7/8" wrench.
Turn the air to the actuator OFF to set the poppet stem into the poppet seat.
Apply water pressure to the valve assembly to verify there are no leaks.
Quickly cycle the valve on and off a few times to purge the system of all contaminants before installing the cutting head.
Re-install the cutting head and continue the cutting process.
Cancel: I did not complete this guide.
One other person completed this guide.
